ittim
Listing all updates
Hi, when I run updater on a client machine I see a list of all past updates with skip against them. The primary one is the only one that can be downloaded.
I want to know if I can prevent all the past updates from showing in the list? Even better would be to not have a list at all and just update the latest version. How can i do that?
Re: Listing all updates
In order to achieve this you can keep only one update entry in your Updates Configurations project or in the "updates.txt" file that it generates.
ittim
So when I do an update I just delete the existing one and replace it?
Yes, you can simply replace the old entry when you add a new update.
