ittim
Vista and Xp - Code Signed install problem
Hi, I've got a sha-256 signed installer which works great. However not with Xp and Vista which I was kind of expecting.
So I assume that I need to set 'sign for compatibility' in the digital signature area.
However when i build using this option I get the same error on install.
"A File that is required cannot be installed because the cabinet file **location** \disk1.cab has an invalid digital signature. this may indicate that the cabinet file is corrupt"
What am I doing wrong?
Using installer 13.1 and Signtool.exe
project.aip
(26.67 KiB) Downloaded 274 times
Re: Vista and Xp - Code Signed install problem
This may also happen if you are using a SHA256-based certificate. If your certificate is issued with a SHA256 hash algorithm, then the certificate won't be recognized on Vista and XP operating systems either. In this case you will need to use a certificate created with a SHA1 hash algorithm. Please take a look on our "Why do I get the "Disk1.cab has an invalid digital signature" error during installation?" faq article.
ittim
Hi Daniel, so would that mean creating two projects? I thought the SHA256 would cover it if I selected the sign for compatibility option
Yes, in this case is recommended to create two projects: one signed with a SHA1 certificate targeting old OSes and the other signed with a SHA256 certificate targeting Windows 7 and newer OSes. Although you can create a single setup signed with a SHA1 certificate this is not recommended as the SHA1 signatures are deprecated due to their vulnerabilities.
