Craig Burke
Uninstall PDFPrinter
I am evaluating using the Professional installer. v13.1
I am using a CA to install a PDF Printer along with our product. We are provided a full installation package with all the necessary files with it's own setup.exe The install is working properly. However, I can not get it to uninstall using a CA during the uninstall of our product. Uninstalling with log file option, the log does not even list our CA at all.
The install for the PDF printer places it's files, including it's uninstall.exe, into a folder under CommonFiles. As part of the testing I am not removing those files ensuring that they are present.
Any ideas what I am doing wrong?
Craig
Re: Uninstall PDFPrinter
Hello Craig and welcome to our forums,
The uninstall custom action may not run if you run the uninstall silently or with basic UI and the custom action was not added as a custom action with sequence in the "Install Execution Stage" in "Custom Actions" page.
When a setup is not running in full UI mode, only the custom actions scheduled in the "Install Execution Stage" are executed.
Let us know if this helped, otherwise please send us the .AIP (project file) and a verbose log of the uninstall to support at advancedinstaller dot com so we can investigate them.
