MLiss@Cetrus.com
Odd crash when installing
While installing I got this error:
ADV.installer crash.PNG (236.52 KiB) Viewed 2789 times
here is the log:
[SEH_AV_DEP_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x0fffff7a]
Advanced Installer Enhanced UI 13.1 build 71115
*** Stack Trace (x86) ***
[0x0fffff7a] -----
[0x6f2630ad] MsiSetOfflineContextW()
[0x6f12a9bc] MsiInvalidateFeatureCache()
[0x6f187d22] MsiGetPropertyW()
[0x008a5be8] -----
[0x008b937c] -----
[0x008a849f] -----
[0x008a7dbe] -----
[0x008a7d5c] -----
[0x008a3f5a] -----
[0x0086b0fe] -----
[0x77429902] RtlInitializeExceptionChain()
[0x774298d5] RtlInitializeExceptionChain()
[0x00800000] MODULE_BASE_ADDRESS
Re: Odd crash when installing
Hello Mike,
Please give us some time to investigate the sent stack trace and we'll get back to you as soon as we have a reply.
Hello Mike,
Unfortunately the above stack trace leads us to an ambiguous result which doesn't offer us any useful info about the error cause. These errors are volatile and very hard to be investigated because they are very hard to replicate. If you find any pattern when such an error appears please try to forward it to us.
Until then, I'm afraid to workaround these errors you will have to just launch again the setup package. Thank you for your understanding.
