I am trying to script as much of the aip file configuration as possible using command line options. The only option listed on the "Updater" tab that I can find documented in the "Command Line" reference is the one to set the auto update configuration file URL.
I would like to be able to script other options via the command line, such as specifying the updater's display file name and description, and the update check behavior (for example, check and always install all updates, without using check frequency). Are there equivalent command line options for these selections in the Advanced Installer U/I?
