mipiz
Registrykey with combobox text
Hi
I want to create a registrykey with the textvalue of a combobox. So I create under "Registry" my key with the name "ADMINGROUP" and I set the comboboxproperty "ADMINGROUP" to.
After the installation the registry was created but it got the combobox value and not the text.
How can I change this? I ve already set the comobbox attribut "Combo List" to "True"
What I get:
What I get:
What I want:
What I want:
Thanks for your help
Mik
Re: Registrykey with combobox text
Hello Mik and welcome to our forums,
This is the normal Windows Installer behavior. The combo box property is always set to the value of the combo box item selected. To achieve what you want you will have to create a custom action to extract the selected combo box item text and save it into another property.
Let us know if this helped.
mipiz
Hi Daniel,
Sorry for the late response.
It works like a charm.
Thank you very much for your help!
Best Regards
Mik
You're always welcome Mik.
