ipollock
Checkbox reverting to true after Save
I have 3 check boxes on a dialogue page, one is set to true (as a default) and the other two are set to false.
Once i save and close the AIP the file date/time updates and that's that...
However when I open the AIP file again and review the check box selection, all three have returned to being
true again.
Any ideas?
Ian
Re: Checkbox reverting to true after Save
Hi Ian,
I'm not sure why you encounter this behavior. Can you please send me your project to our support email address and also tell me which those check boxes are, so I can investigate them and try to find the problem?
ipollock
Thanks for getting in touch.
I have managed to resolve this issue as it was tied into a search that was not able to resolve and
the wrong variable.
Ian
You're welcome Ian. I'm glad you solved the problem.
