I'm not sure why you encounter this problem. Did you follow all the steps described in the "
Folder Operations in the Files and Folders Page" article in order to create your property-based folder?
You can place some files in the "Application Folder" from the "Files and Folders" page of your project, then set its paths in the "Application Folder" field from the "Install Parameters" page and you can place the other files in a property-based folder and set the path of that folder through a custom action as described in the article mentioned above.
If you still keep getting errors please send us the .AIP (project file) and a
verbose log of the installation to
support at advancedinstaller dot com, so we can investigate them?
