MLiss@Cetrus.com
How do I read and capture database information to an XML file?
I would like to read an existing xml file (if it exists)
Gather Database information using the SQLServerConnectionDialog
Finally, write out the database information to the xml file
I have attached a project that I have started... but I can't detect the xml file... nor will it write out the new settings
Can you help me out?
Mike
DBAccessTest.zip
(10.93 KiB) Downloaded 251 times
Re: How do I read and capture database information to an XML file?
Hello Mike,
To search for an element within the XML file you can use an XML Search. If you need only to check if the XML file exists, then you can simply use a File Search.
Your XML file update seems to be configured fine, but I suggest you instead of using private property name (i.e. DB_Server, DB_TrustedConnection, DB_UserName, etc.) you should use public property names (e.g. DB_SERVER, DB_TRUSTEDCONNECTION, etc). This is because the values of private properties get reset when the installation moves from "Wizard Dialogs Stage" to "Install Execution Stage".
Let us know if this helped.
MLiss@Cetrus.com
Daniel,
Thanks for the help... I have changed them to "public" and it's writing out the values now..
but
here is the file:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<Manager>
<DB>
<Server _Server="LAPTOP3080\SQL_EXPRESS">This is the DB Server name</Server>
</DB>
</Manager>
What I need is to put the "value" into xmlElement instead of an attribute
<Manager>
<DB>
<Server>LAPTOP3080\SQL_EXPRESS</Server>
</DB>
</Manager>
How is this achieved ?
Thannks
Hello Mike,
To achieve this you should only use your a formatted reference of your server property in the "Text" section of your XML element.
You're always welcome.
