MLiss@Cetrus.com
SqlServerConnectionDialog will not honor timeout values
I have set the timeout values of the SQLServerConnectionDialog to 5 seconds each (see attached images and project)
and
but when I test the connection to an invalid server, the timeout goes for a minute
Why?
DBAccessTest.zip
(10.93 KiB) Downloaded 256 times
Re: SqlServerConnectionDialog will not honor timeout values
Hello Mike,
To specify the timeout for the test ODBC action you should set the "SqlConnectionTimeout" property. You can go in "Install Parameters" page and add a property like this:
  • Name: SqlConnectionTimeout
    Value: 5
MLiss@Cetrus.com
What are the other timeout values used for?
( your suggestion worked as well )
Hello Mike,
You can use any value between 0 and 10000 (seconds).
