MLiss@Cetrus.com
(local) not connecting
I have a setup project where I am using the SQLServerConnectionDlg and the server is initially set to the predefined (local)
However, when I run it, it does not connect.
( I show SSMS running in the background to provide a reference to the instance name of the Database )
When I specifically call out the machine and instance it works.
It does pick up other SQL Server boxes on the network... so I assume the search is working...
Mike
I am on Windows 7 and SQLServer 2014 Express
FleX
Re: (local) not connecting
I don't work for Advanced installer or anything, but I do a lot with SQL Servers. Try putting the SQL_Express after your local like this : (local)\SQL_Express.
Local essentially takes the place of your computer name. You still need to reference the SQL instance.
MLiss@Cetrus.com
I did some research on SQL server and it turns out I did not have SQL Server Browser service enabled or running ...
as soon as I enabled and turned on the service...
it worked.
Consider this closed.
I'm glad you got this working. Thank you for sharing the solution, I'm sure it will help other users in the future.
