ameen.jinnah
Multiple Instance Web Application
Recently we purchased Advanced Installer and I'm very new for this. First time we are building the installer for our web application.
Our requirement is, the installer should work for multiple instances of web application resides in the same server. Based on the user guide, I'm able to create multiple instances of installation. But I want each instances to be configured as individual application under IIS > Default Web Site. I'm struck on this.
I have attached the AIP file. I want the instance name to be the application name.
Kindly reply me. I have already browse through all the forums that speaks about multiple instances, but i found no answer how to configure the IIS web site name to be a instance name.
Thanks.
Ameen.
CURA3.0.aip
Sample AIP attached,
(16.87 KiB) Downloaded 273 times
Re: Multiple Instance Web Application
In order to achieve this you can go in the "IIS" page and use the [ProductName] property in the "Name" field of your web site as displayed in the attached image.
WebSite Name.png (30.95 KiB) Viewed 3136 times
ameen.jinnah
Hi Eusebiu,
Thank you very much. This is working for me.
You're welcome. Glad to help.
