nlfdss
License Server Monitoring Information
The Advanced Installer Network License Server has monitoring available at http://<server>:<port>/admin. As the license server generally needs to be running the same version of Advanced Installer as the clients, it would be nice if this page displayed the version of Advanced Installer that the license server was running.
Additionally, it would be nice if this information was potentially available in a JSON/YAML format, to allow for easy consumption by monitoring services and scripts.
Re: License Server Monitoring Information
Thank you for your suggestions. I've forwarded your thoughts to our development team and hopefully they will consider such improvements in the future.
Also, as a side note, please note that it is not mandatory to use the same version of Advanced Installer for the AI License Server and for the AI client applications. You can use different versions for the client and server app without any problem.
nlfdss
Hi there,
Is there an option to "bump" feature requests like theses?
Unfortunately not. The priority for the improvement requests are set based on the requests number and also on the availability of our development team. Thank you for your understanding.
As a side note, can you please give us more details why would you need to check for a version mismatch between the License Server and the AI clients?
Also, please give us more details about what info would you like to be exported into a JSON.
Return to “Feature Requests”
