MLiss@Cetrus.com
application start
I have an installer that is set to kill the application if it is running
And to start the application after it is installed.
When the installer is manually run (the user double clicks it), the application is killed and then it starts at the end of the install.
However, when I programmatically start the application (using C# and "Process.Start" and a quiet install)
the application is killed (I see the application disappear from the task manager),
the new application successfully installs ( I check version number on the file and it is the new version)
but then it fails to restart
I have attached the logs to see if there is anything in the installer log that would indicate why it is not starting from a programmatic install.
Mike
AgentInstallLog.txt
(403.71 KiB) Downloaded 250 times
Re: application start
Hello Mike,
The encountered behaviour is correct since the installation is done silently while the application is launched on the ExitDialog when the user hit the Finish control.
In order to launch your application when the installation is performed silently, you can use the predefined Launch File custom action as a custom action with sequence, executed after the files have been coppied on the target machine. You should condition the custom action so that it should be executed only when the installation is performed silently. For this, you can take advantage of the UILevel property.
You can use the attached image for your reference:
LaunchFile CA Props.png (41.53 KiB) Viewed 2958 times
Please let me know if you need any help.
MLiss@Cetrus.com
Daniel,
Thanks... I will incorporate these changes into my next build
Mike
