MLiss@Cetrus.com
Possible new line in XML value ...
I have built an installer that uses the advanced installer file search and the advanced installer XML read/save capabilities ...
However, when I run the installer, I am getting a weird XML issues from the "Port" value.
it seems the 'value' of Port has a new line appended to the end of it:
Here is a snapshot viewing the XML file from IE:
Here is a snap shot of the XML file in Visual Studio editor:
See attached project for any possible errors that I may have introduced by using Advanced Installer incorrectly?
Mike
DbInstallTest.zip
(12.42 KiB) Downloaded 266 times
Re: Possible new line in XML value ...
Hi Mike,
I looked over your project and I noticed that the "Port" element contains a space character and a new line character after the "[SVR_PORT]" property. Can you remove them and see if the problem persists?
MLiss@Cetrus.com
thank you ... that solved the issue.
You're always welcome.
Just let us know anytime you encounter a problem.
