MLiss@Cetrus.com
SQL trusted connection not working correctly?
I have a project that uses the SQLServerConnectionDlg and am experiencing some weird behavior.
When I UNcheck the trusted connection and enter a password, (user name is empty), the connection succeeds - INCORRECT behavior.
When I UNcheck the trusted connection and enter an incorrect user name and password, the connection fails - correct behavior
I have attached my project
Mike
NOTE: My database does have a user that uses SQL Authentication and the project does succeed when I use the correct user name and password
DbInstallTest.zip
(12.42 KiB) Downloaded 250 times
Re: SQL trusted connection not working correctly?
Hi Mike,
I tested the scenario and, indeed, I reproduced the behavior. It seems that the "SQL Server" driver uses the "trusted connection" method when an user name is not specified. We will investigate this and try to improve it in a future version of Advanced Installer. Thank you for bringing it to our attention.
Meanwhile, you can add some control conditions on the "Test Sql Connection" button so that it will be enabled only when the "Trusted Connection" option is checked or when an username and a password are specified.
Just let me know if you have any question.
Hi Mike,
As I mentioned above, we will try to add an improvement to this in a future version of Advanced Installer. In the meantime, you can use the workaround suggested in my previous post.
You're welcome Mike.
