MLiss@Cetrus.com
Check box value not saving to XML file
I have an installer where I am saving some SQL parameters. One of the parameters is if the connection is trusted or not.
(TrustedConnection)
The value is based on a check box in the SQLServerConnection dialog.
I would like either "true" or "false" ( boolean value ) to be stored in the XML file, but the project is not doing that.
I have attached the project for your inspection.
Mike
ManagerServiceInstaller.zip
(494.71 KiB) Downloaded 250 times
Re: Check box value not saving to XML file
Hi Mike,
The property related to the checkbox is empty when the checkbox is not checked. When you check it, the property's value is set to the value specified in the "Value" field.
In order to populate the "<TrustedConnection>" XML element when the check box is not checked you can use a different public property which is set depending on the state of the checkbox.
To achieve this you can follow the steps below:
- in "Install Parameters" page, create a property (i.e. "TRUSTED_CONNECTION") with the default value set to "True"
- using a "Set installer property" custom action with sequence in "Install Execution Stage" after the "Searches" action group, you set the property created above ("TRUSTED_CONNECTION") to the "False" value if "DB_TRUSTEDCONNECTION" property is not set (condition is: "NOT DB_TRUSTEDCONNECTION").
- use the "TRUSTED_CONNECTION" in your XML file to update the "<TrustedConnection>" element
This way, the "<TrustedConnection>" XML element will always have a value.
