1. Go to the Prerequisites
2. Add the "Predefined Prerequisites," "SQL Server 2014 SP2 x64"
3. Move into Pre-Install.
4. Edit the field in the Minimum Version 12.0.5000.0 on 12.0.4213.0 (SQL Server 2014 SP1 x64) or-12.0 (SQL Server 2014 x64)
5. Build the installer
6. Run
We expect:
In the installation of additional components in the "Found" - 12.0.4213.0 or 12.0 (depending on which version we have installed on your PC)
Got:
in the "Found" - empty. Although the PC version is already installed 12.0.4213.0
Hence - a necessary condition is not satisfied. And you need to install the next version of the installer that asks.
PS: The condition is met if only to reduce the major version. For example, on 11.0. But in this case, the conditions precedent window is not displayed at all.
Also, it is met, if the version installed on the PC to match the version provided. And then, in the window to install additional components to it it is displayed.
PPS: And also I would like to list Predefined Prerequisites in accordance with the established design language. Now all English-language packages, matter what language is selected in the installer project.
