MLiss@Cetrus.com
SQLExecDirect error message
I have just added a script to my installer and I am getting an error message that I believe is purely informational
(according to this site: https://msdn.microsoft.com/en-us/librar ... s.85).aspx )
Here is a snapshot:
I have also attached my install project for your inspection
( I have removed most of the DLLs and the prerequisites from the installer... but hopefully that won't be an issue as the program doesn't need to run to experience this problem... it's during the install when the problem manifests)
Mike
Manager.zip
(308.59 KiB) Downloaded 316 times
Re: SQLExecDirect error message
Hi Mike,
This is an SQL Driver predefined message that appears when the working database is changed. In your case, you connect to the "master" database through your predefined connection and then connect to another database through the following line from your SQL Query script:
Use [PMInfrastructure]
In order to avoid this message, you can connect directly to the "PMInfrastructure" through the predefined connection and remove the following lines from your SQL Query script:
IF NOT EXISTS (SELECT name FROM master.sys.databases WHERE name = N'PMInfrastructure')
BEGIN
	create database PMInfrastructure
END
Otherwise, you can try the method suggested in the "How to stop the “Changed database context to …” message" thread.
MLiss@Cetrus.com
thanks... giving this a try
You're welcome Mike.
Just let me know if you have any question.
