Andym301
unexpected error 1624
I have a multilingual Setup done with professional 13.3 (and previous Versions). Each time I try to install I get this unexpected error 1624 when Setup tries to unpack the temp files in user temp Directory for preparing Setup. This happens only on US american english (the Project language). It does not happen in any other selected languages (5). This behaviour is new as we did this type of setups since some years and in previous version of advanced installer I never got this problem.
The problem is present on different machines. Attached is the error message and verbose log.
For testing purpose, I also created a very simple testproject with two languages just to see if only the specific project is the problem but it happens there as well.
Please advise what we can do
Andy
Trichoverboselog.log
(264.68 KiB) Downloaded 224 times
Re: unexpected error 1624
Hello Andy,
I've tested the scenario, but unfortunately I am not able to replicate the issue.
Could you please forward us a small buildable sample (AIP + its referenced files) or a detailed list of steps we should perform to replicate this issue?
Thank you for your help into this matter.
Hello Andy,
This is just a follow up.
We had another user with the same issue and he helped us to replicate the problem. This seems to be an Advanced Installer issue which happens when you are building a multilingual setup with the "Display language selection dialog" option selected. When choosing, at install time, any other language than the target system language this error occurs.
A fix will be available in a future version of Advanced Installer. We will update this thread you as soon as the fix will be out.
Until then, as a workaround you can go to "Translations page -> Languages tab" and use the "Automatically use system language for installation" or "Automatically use current user language for installation" option instead of the "Display language selection dialog" option.
This was fixed in version 13.5 of Advanced Installer released on December 14th, 2016.
