prerak6962
Error 1624
I have an installer of type "mixed package" and it supports 2 languages, English and French.
While installing the product in English, everything works fine but when I install it using French language, I get the following error:
Log file
Log file
Error 1624.png (7.16 KiB) Viewed 8867 times
As per the Microsoft's documentation it is related to patches but I don't use any patches.
Also, in the "Builds" tab, I selected "Do not delete extracted MSI and CAB files" but the behaviour was the same.
In "Translations" tab I have following options selected "Create only a multilingual package" and "Display language selection dialog"
I have also attached the log file if it can be useful.
Advanced Installer version 13.3
Any idea how can I solve this?
Thank you.
Prerak
log2A32.log
Error image
(159.58 KiB) Downloaded 409 times
mihai.petcu
Re: Error 1624
Does this behavior manifest on several clean machines or is it just this one?
If it does please send us the project file(AIP) and other dependencies(or samples) along with a test case so we can build and replicate the issue. Please send them over e-mail to support at advancedinstaller dot com.
prerak6962
Re: Error 1624
It happens on couple of machines but not on one on the clean machines.
But how can I be sure that it won't happen on any of my users machine? And if it happens, what can be the solution/work around to resolve it?
Prerak
prerak6962
Re: Error 1624
Upon further testing, I discovered that it is happening on all my machines.
I have attached the .aip file of the project.
To reproduce it:
  • 1. Run the exe file
    2. Change the default selected language in the "Select language dialog"
If I keep the language as it is, everything works fine but upon changing the language I get the previously mentioned error.
On some machines it shows default selected language as English and on some it's French. So it is not dependent on the language.
Also for the machines on which the default selected language is French, if I change it to English, the UI appears in English. But the error still appears in French language.
Prerak
TestApp.aip
AIP file
(29.67 KiB) Downloaded 475 times
Re: Error 1624
Hello Prerak,
Indeed this is an Advanced Installer issue. We isolated this on our side too and a fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention. This seems to be an Advanced Installer issue which happens when you are building a multilingual setup with the "Display language selection dialog" option selected. When choosing, at install time, any other language than the target system language this error occurs.
We will update this thread you as soon as the fix will be out.
Until then, as a workaround you can go to "Translations page -> Languages tab" and use the "Automatically use system language for installation" or "Automatically use current user language for installation" option instead of the "Display language selection dialog" option.
