BlackCloud
Code signing
We have a Comodo code signing certificate that doesn't want to play. No matter what options we choose, it always generate the following error
Please advise.
Re: Code signing
Can you please tell us if the behaviour still persists after importing the certificate in your Personal Store? If you already are using this option, can you please check if the certificate is properly imported in your Personal Store?
Does it makes any difference if you select the certificate from the disk?
