MLiss@Cetrus.com
Installer forcing reboot when not necessary
I have an installer that has had this setting for literally months and when ran the installer, NO REBOOT occurred.
After the last upgrade to AdvancedInstaller 13.4, my installer is rebooting the computer every time it runs.
I initially thought everybody in our office might have had a windows installer upgrade or something..
then I ran the installer twice on the same machine and the machine rebooted each time...
I am beginning to think something changed in your code. I have attached the installer log.
HERE IS THE LINE IN THE INSTALLER LOG :
MSI (s) (E4:A4) [12:37:42:996]: Windows Installer requires a system restart. Product Name: Agent. Product Version: 3.2.88.0. Product Language: 1033. Manufacturer: Cetrus. Type of System Restart: 1. Reason for Restart: 1.
Why?
ps:
I have changed my installer to use these settings until you can investigate:
2016.11.22.12.37.07.952_DBorde_AgentInstallLog.txt
(411.28 KiB) Downloaded 468 times
Re: Installer forcing reboot when not necessary
Hello Mike,
This happens because during the uninstall of the oldproduct there are some files (to be uninstalled) which are held in use by another processes. You can see the following in your log file:
MSI (s) (E4:F8) [12:37:39:442]: RESTART MANAGER: Will attempt to shut down and restart applications in no UI modes.
MSI (c) (D4:94) [12:37:39:442]: RESTART MANAGER: Failed to add process ID 928 resource; Windows Installer will use the built-in FilesInUse functionality. Error: 22
So, as a workaround, you can use in the setup project of your old product version our "Terminate Process" predefined custom action on uninstall. You should stop on uninstall all the processes which could keep in use the installed files.
Also, to check which files are kept in use you can run the setup with full UI and the "FilesInUse" dialog should be displayed by WIndows Installer.
MLiss@Cetrus.com
Daniel,
I have... any other suggestions?
Mike
MLiss@Cetrus.com
As to the use the full UI ... I cannot... this install HAS to be silent.
Hello Mike,
Please move your detect and stop process custom actions in the "Install Execution Stage" (before or after the "Searches" group). This is the correct execution stage when they should be triggered.
Also, please keep in mind that during a silent installation only the "install Execution Stage" is executed. All the other actions are ignored.
Let us kow if this helped.
MLiss@Cetrus.com
Daniel,
Thank you... I will try this.
You're welcome.
