I'm not sure why you encounter this problem. Can you please send us your project to support at advancedinstaller dot com, so we can investigate it and try to find the problem?
I tested your project in a debug version of Advanced Installer and it was built successfully. Can you restart your machine and see if the problem persists? Also, can you change the "Output -> Folder" path from the "Builds" page and see if it works? If not, can you also test it on multiple clean machines?
I think the problem is because of our network. It is have become slow since since we moved our environment externally last Friday. I noticed that even copying a 10MB file now takes ages. So the problem is not yours but ours. Sorry for troubling you.
I thought all my problems had gone away, however I have attached an error I am getting when I am creating new project. This has started since I upgraded to the latest version?
Unfortunately, this happens due to a recent Advanced installer issue which we are already aware of. A fix for this issue will be available in our next version of Advanced Installer. We will notify you as soon as this will be available.
Until then, as a workaround you should install PowerShell 3.0 on your machine.
