MLiss@Cetrus.com
Advanced Installer Crashing
I have a service installer that installs a window service.
NOTE: when the service starts it tries to connect to the Database that is verified and created by the installer.
I think I have the installer setup so it performs the correct sequence of steps however, when I run the installer it crashes.
I have attached the advanced installer setup project as well.
ManagerServiceInstaller.zip
(508.06 KiB) Downloaded 240 times
MLiss@Cetrus.com
Re: Advanced Installer Crashing
This has now happened on two entirely different installers.
Hello Mike,
We tested your sent setup file on several machines (Server 2008 R2, Server 20012 R2) multiple times, but we cannot replicate the crash. Can you consistently replicate the crash?
If so, it will be useful to forward us a test case (scenario) when this crash consistently occurs.
MLiss@Cetrus.com
Daniel,
It is a random occurrence.
The installer I sent you did it.. .and a totally different installer did it as well.
Is there any debugging stuff I can turn on to record for a while to hopefully catch it?
Hello Mike,
Unfortunately there is no debug tool you can use. Next time when this error occurs please copy the whole ACCESS VIOLATION stack trace and send it us so we can try to process and analyze it on our end. Maybe we will manage to find someting useful in the stack trace about the scenario when the error replicates.
