MLiss@Cetrus.com
ODBC Validation without database name specified
I have an installer that uses the SQL Server connection dialog.
I have used the functionality as you have provided it. I think I may have changed variable names, but not any functionality of the dialog.
(the project is attached)
The dialog has a "Click here to test SQL connection" hyper link.
I believe there is a bug : When I am testing, the dialog appears to successfully validate the connection
using a trusted connection, EVEN THOUGH the database name is empty???
( I have not tested using a sql connection - but I assume it would do the same? )
ManagerServiceInstaller.zip
(508.06 KiB) Downloaded 233 times
Re: ODBC Validation without database name specified
Hi Mike,
The "Database" is, by default, not specified in the SQL connection string used to test the connection due to the "Create database if it does not exist" option that is checked in the "SQL Databases" page.
If that option is checked, we consider that the connection will succeed during the installation because even if the database does not exist, it will be created automatically. So, basically, the test connection action only tests the connection to the server, not also to the database.
If you want to test the connection to the database, you can select the "Click here to test SQL connection" hyperlink, then modify the value of its "[SqlConnectionString]" published event as in the example below:
Driver=[\{]SQL Server[\}];Server=[SERVER_PROP];Database=[DATABASE_PROP];Uid=[USERNAME_PROP];Pwd=[PASSWORD_PROP];
Just let me know if you have other questions.
You're welcome Mike.
Just let me know if there is anything else that I can help you with.
