cblaise
Support for asp.net core
Does Advanced Installer currently support asp.net core? If so, is it limited to being hosted in IIS or can in run as a self-hosted service like typical asp.net applications?
Re: Support for asp.net core
I'm afraid that we do not have support for this yet. However, this feature is already on our TODO list and we will try to add it in a future version of Advanced Installer. We will update this thread when it will be available.
richardw
Can I ask what the current situation with ASP.Net core support is?
I have an ASP.Net Core 2.0 app (built with .Net 4.7.1 rather than .Net Core), and can build an installer that directly installs that into an IIS server that already has the required dependencies installed. However, if I create a web deploy package for the same application and add that into an AI installer, I get the following error when I try to build the install:
Error calling MSI API: 1627 Method: MsiDatabaseImport Table: AI_IIsWebDeployParams. Extended Error: 1: 2216 2: C:\Dev\TFS3WebApiGit\installer\Your Application-SetupFiles\Your Application.msi 3: AI_IIsWebDeployParams.idt 4: 4 .
Advanced Installer 14.9 build d1a66ff2f1
*** Stack Trace (x86) ***
[0x74bfd722] RaiseException()
[0x026ea6dd] -----
[0x016c518c] -----
[0x016c0c29] -----
[0x016dbfe6] -----
[0x016dad65] -----
[0x016143c9] -----
[0x0161cc86] -----
[0x014d21c5] -----
[0x01611130] -----
[0x01289721] -----
[0x01289729] -----
[0x011d12e5] -----
[0x011da0fc] -----
[0x01e9c170] -----
[0x019363d1] -----
[0x770f2ec0] RtlValidSecurityDescriptor()
[0x770f2e90] RtlValidSecurityDescriptor()
[0x00e20000] MODULE_BASE_ADDRESS
This is with AI 14.9 and a basic ASP.Net Core app created with the Visual Studio 2017 project template.
Doing the same with an ASP.Net package seems to work ok, so i'm not sure if this would be 'expected' due to lack or support for Core?
Richard Webb
Hi Richard and welcome to Advanced Installer forums.
Sorry for the delayed reply.
I'm afraid that the Asp.Net Core was not added to Advanced Installer yet. I increased its priority and hope to add it soon. We will update this thread when it will be available.
That error seems to appear because the project contains duplicate or incomplete rows in the "AI_IIsWebDeployParams" table, but I'm not sure why this happens.
Can you send me, to support at advancedinstaller dot com, your AIP (project file) and the web deploy package that you try to import, so I can investigate them and try to find the problem?
richardw
On closer investigation, the error seems to be down to a missing value for the 'IIS Web Application Name' parameter:
It builds ok if I manually set a value.
The parameters.xml file in the ASP.Net Core web deploy package contains
<parameter name="IIS Web Application Name" value="Default Web Site" tags="IisApp">
Wheres a similar trivial package for ASP.Net contains
<parameter name="IIS Web Application Name" defaultValue="Default Web Site/WebApplication2_deploy" tags="IisApp">
Which might explain the difference in behaviour between them?
This occurs with a new basic asp.net core 2.0 app and a new AI project without any other log in it, but I can mail examples to you if you still want them.
Richard Webb
Hi Richard,
Indeed, the lack of that value caused the build failure. I'm glad you found and resolved the problem.
It would be really helpful if you could send me an example and the steps that reproduce the problem to support at advancedinstaller dot com, so we can investigate and fix it.
richardw
Ok, mailed. (had a little delay as the package I was testing with was too large to mail, so I created a smaller .Net Core package instead).
Richard Webb
Hi Richard,
Thank you very much for sending me the sample project.
I tested the scenario and, indeed, I reproduced the problem. I will submit this case to our development team to investigate why a default value is not set for that parameter and fix this in a future version if this is really an Advanced Installer issue.
This was fixed in version 16.1 of Advanced Installer, released on July 2nd, 2019.
Carignankg
And what about the support of most recent .net core 2.2?
Unfortunately, we do not offer a predefined prerequisite for .NET Core 2.2. We offer predefined prerequisites ("Prerequisites" page --> "Packages") for the following:
- .NET Core Runtime 2.1.5 - x86 & x64
- .NET Core IIS Hosting 2.1.5
However, we already have this on our TODO list and as soon as this will be implemented, I will update this thread.
Until then, you can simply download the .NET Core setup from the official Microsoft website and then add it to your package as a prerequisite.
This improvement has been added in version 16.2 of Advanced Installer released on August 1st, 2019.
Return to “Feature Requests”
