prerak6962
Dialog Windows black on Win 7
I am facing a weird issue for the installer on Win 7. The dialog background is completely black. You can see the screenshot of the dialog below:
As per this thread I changed the "Image Scaling" option under "Themes -> Settings" to "Always stretch images to fit their control window bounds" but the result was the same.
Advanced Installer version: 13.4
Kindly let me know is the bug corrected in this version or what can be a temporary solution?
Thank you.
Prerak
Re: Dialog Windows black on Win 7
Hello Prerak,
I'm not sure why this happens. Can you please send us your AIP (project file) and the image file you use for your dialog background to support at advancedinstaller dot com so we can investigate them?
