kietvta
Run script to insert data to SQL Sever CE
Dear Sir
My deployment connect to SQL Sever CE. It had already extracted file .sdf to installed folder automatically.
Now I want to insert data to some tables in that database.
Would you mind to show me how to create script file to connect to SQL Sever CE automatically
and get data from users input on the initial setup (I have designed Folder Dialog to get data) to insert data to some table
Thank you so much.
Kietvta
mihai.petcu
Re: Run script to insert data to SQL Sever CE
Hello Kietvta,
To configure a script using installer properties(e.g. public properties attached to UI controls), you can follow this article:
How to use a custom property in a SQL script?
Also, you can find related step by step tutorials here:
Using SQL Databases tutorials
kietvta
Dear Mihai
Thank you for your reply.
What is the connection string to connect to SQL SERVER CE database?
I made custom connection by go to "SQL database -> database server -> new connection -> custom as image attached here.
Regard,
Kietvta
CUSTOM CONNECTION.png (22.61 KiB) Viewed 20159 times
mihai.petcu
Hello Kietvta,
Depending on the data provider, you can configure SQL Server CE connection strings as indicated here:
SQL Server Compact connection strings
To do this you can still use a custom connection type, but instead of the standard SQL connection string, try one from the article linked above. The custom connection string field is also formatted type so you can still reference installer properties.
kietvta
Hi Mihai
Thank you so much for your support.
