fakeid112
unable to find type [string]
when i create installer for visual studio project and select the solution and error comes up "unable to find type[string]: make sure that assembly containing this type" i also attached a screenshot please solve it asap thankyou :)
Re: unable to find type [string]
Just install PowerShell 3.0 on your current machine and this issue should be fixed. Please take a look on our "Build Project error" forum thread.
fakeid112
Daniel wrote:Hello,
I downloaded powershell but when i launch the setup it says "the update is not applicable to your computer"
Just please make sure you downloaded the correct package for your operating system and architecture.
  • Windows 7 Service Pack 1
    ---64-bit versions: Windows6.1-KB2506143-x64.msu
    ---32-bit versions: Windows6.1-KB2506143-x86.msu
    Windows Server 2008 R2 SP1
    Windows Server 2008 Service Pack 2
    ---64-bit versions: Windows6.0-KB2506146-x64.msu
    ---32-bit versions: Windows6.0-KB2506146-x86.msu
Let us know if this helped.
fakeid112
Daniel wrote:Hello,
infact i downloaded all of them and checked each one of them every package says the same and i have windows 7 sp1 64 bit
Please make sure that .Net Framework 4.0 is already installed on your machine before trying to install PowerShell 3.0. Just follow the "Install PowerShell 3.0 on Windows 7" article steps and let us know how this worked.
fakeid112
Daniel wrote:Hello,
done all the things still powershell 3 says this update is not applicable to your computer tried on .net 4 and now 4.5 also and updated the windows updates too but still that error :(
Can you please make sure that there is no previous version of Windows Management Framework 3.0 already installed on your machine. Open "Control Panel" and go to "Programs->Uninstall a program->View installed updates". Here search for any installed
KB2506143 update and uninstall it. Then try to install again the Windows Management Framework 3.0.
fakeid112
Daniel wrote:Hello,
no there is not any update for KB2506143
fakeid112
I figured out the problem I had simple win 7 not service pack 1 now I updated it service pack 1 and power shell is started but now it says this
Please make sure no Powershell.exe process i running during the "Windows Management Framework 3.0" MSU installation.
Also, before the installation please execute a system reboot. Maybe there are some pending updates which could block the installation of the current update.
fakeid112
Daniel wrote:Hello,
tried everything you told but still same error :(
I'm afraid I run out of ideas. I don't know anything else what you could try. Maybe you could ask on Microsoft forums about how to successfully install PowerShell 3.0 on your machine.
