MLiss@Cetrus.com
Package will not uninstall
I have an installer (attached) that when I install it on Windows Server 2008 R2, then immediately go to control panel (remove programs) and uninstall it, I get the following error:
( NOTE: this is happening to ALL 4 of my installers... )
I am a local administrator as well as a domain administrator. I have full control to any directory on the machine.
mihai.petcu
Re: Package will not uninstall
We built and tested your installer on a Windows Server 2008 R2 machine but unfortunately we didn't get any error. Does this happen on other (clean) machines?
This error usually occurs when the folder path used in the msiexec log command line doesn't exist on the target machine. The /L*V argument can create the log file providing the folder structure path already exists on the target machine.
MLiss@Cetrus.com
Is there some command that can create the folder structure path?
Hello Mike,
The folder structure path of the log file should be automatically created by the installation process if the current user has write permissions on that location. Did you get this error when manually launching the EXE setup package to uninstall the product?
For testing purposes, can you please go to "Install Parameters" page, uncheck the "Enable verbose logging" option, rebuild and test again the scenario and see if the issue still happens?
As a side note, for security reasons please note it is not recommended at all to disclose your digital certificate file outside of your company boundaries. Thus I have deleted your ZIP attachment containing your setup project file from this thread.
