Antarctica
Checking database access
I have implemented ODBC connection check, but I am unable to check that the user provided has in fact access to the database given (read, write and schema).
With a user that has no permissions on database "testdb", the connection check runs through okay, but when trying to connect for install, the installer then returns {SQL_STATE: 42000} Cannot open database "testdb" requested by the login. The login failed.
Is there a feature somewhere to get the user permissions after odbc connection check or would that be a custom action?
Re: Checking database access
I'm afraid we don't have predefined support for this check. You can try to create and develop your own custom action for this indeed.
Return to “Feature Requests”
