Yes, you can use an existing .AIP(project file). In order to achieve this, after you added the Advanced Installer Project to the Visual Studio solution, you can delete the default .aiproj (AI Setup Project) that is created. Then, you can use the
Add -> Existing Item context menu option to add an existing .AIP(project file) to the VS solution. Use the below image for your reference:
- Add Existing AIP.png (22.77 KiB) Viewed 2873 times
Please let me know if you need any help.
