GeorgeNJ
BUG: Registry tab slider
The slider on the registry tab will not stay where I put it. I move it then next time I run AIP it is moved back to where it was.
Re: BUG: Registry tab slider
Can you please tell us what version of Advanced Installer are you using? If you are not using the latest version, can you try to see if the behaviour still persists when using the latest version?
Also, please send us the .AIP(project file) to support at advancedinstaller dot com so we can further investigate this.
