Eric_Liu
How can I bypass this error ?
I need to create a MST file for customize the chrome MSI.
(The 32-bit MSI source can be downloaded from https://enterprise.google.com/chrome/chrome-browser/ )
However, when I try to move the installation sequence, Advanced installer force me insert the OptOmahaArgs value.
But the default value is "BLANK"
I can't save the mst file if i leave this value blank. How can I bypass this error ?
Re: How can I bypass this error ?
That is a "Set installer property" custom action where the "Property" and "Value" fields are mandatory. In order to set a property to empty using that custom action, you write the following characters in the "Value" field: {}
Can you try this and see if it works for you?
Eric_Liu
Chrome is able to install even thought set this value to other value. ( 1, 2 or 3 also OK)
I'm not sure the functionality of this value.
I tried to open the mst (mst created from Advanced installer) by Installshield, I can see this value is saved as {} , not empty
Can you confirm {} absolutely equal empty ?
P.S. Installshield is able to save even thought this value is empty.
The "{}" value is written in the configuration of the "Set installer property" custom action which will be interpreted as empty during the installation.
Eric_Liu
OK. Thanks for your help.
You're welcome.
Just let us know anytime you need assistance.
