Eric_Liu
[Bug Report] Shortcut is able to pin to taskbar even though set to disabled
Hi Advanced installer support team
I'm following this tutorial to set the shortcut properties, but i get a bug in Windows 8.1.
http://www.advancedinstaller.com/user-g ... ialog.html
Let me show you an example.
I downloaded the source from
http://www.cpuid.com/downloads/cpu-z/cpu-z_1.78-en.zip
Create a new installer, add the source folder to application folder
Then, right click cpuz_x64.exe, new short cut to > Installed file
Pin to taskbar set to disabled.
Build the msi file.
Install the msi file in windows 7 and windows 8.1, then launch the cpuz program from desktop shortcut.
Windows 7 is unable to pin the shortcut. < OK, no problem
Windows 8.1 is able to pin the shortcut. < Bug (Click Pin this program to taskbar, then right click the program icon in task bar once again, the program will pin to taskbar)
Do you have any alternative solution can provide ?
mihai.petcu
Re: [Bug Report] Shortcut is able to pin to taskbar even though set to disabled
Dear Eric,
I replicated the bug and sent it to our dev team to investigate. We'll keep you posted here, thanks for the detailed report.
Eric_Liu
Hi Support team,
This bug still not fixed in version 13.6.
I'm afraid not. We will try to include a fix in one of the next versions of Advanced Installer. As soon as the fix will be out we will update this thread too.
