Eric_Liu
[Bug Report] Unable to create MST file for Arbortext Editor 7.1
Hi Advanced Installer support team
An error occurred while trying to create a transforms file for Arbortext64.msi
The source can be downloaded from
http://download.ptc.com/products/arbort ... 1480095499
Re: [Bug Report] Unable to create MST file for Arbortext Editor 7.1
Thank you for your sent files.
I've tested and replicated the issue. We will further investigate the sent MSI file and will let you know the resolution.
A fix for this issue will be added starting with our next version of Advanced Installer (13.6).
We will update this thread as soon as the next version will be out.
This was fixed in version 13.6 of Advanced Installer released on February 15th, 2017.
