kietvta
Dialog to install prerequisites file with check box and installed status
Dear all
Would you mind to show me how create a dialog to install prerequisites files that the users can decide which files will be installed by clicking on check box.
It also can show the filename, version,selected status ( Install or Skip) and installed status (already installed or Not Install ) next to checkbox as attached image.
After the users click on button [Next], system will all selected files .
Thank you in advance.
Kietvta
custom dialog.png (70.26 KiB) Viewed 7042 times
Re: Dialog to install prerequisites file with check box and installed status
To achieve what you ask you should add all of your prerequisites as feature-based prerequisites and add in "Dialogs" page the "PrerequisitesDlg" dialog.
You're always welcome.
Return to “Feature Requests”
