FrankXu
In the run mod,label's backcolor has problem.
Dear
please see the attachment,can you help me?
1222-QA.zip
(144.13 KiB) Downloaded 335 times
Re: In the run mod,label's backcolor has problem.
This may happen if you didn't enable the "Enhanced User Interface" feature. Please note that, excepting the Classic" theme, all our themes require the EUI feature to be enabled. Also, the built setup package type should be an EXE.
So, just go to "Builds" page -> "Configuration" tab and make sure an EXE package type is selected. Then, from "Themes" page -> "Settings" tab make sure the EUi feature is enabled on install or always.
Let us know if this helped.
FrankXu
Dear
I tried it.Install is ok.but when i unstall by modify menu.error is displayed.please see the attachment.
Can you please send us your AIP (project file) to support at advancedinstaller dot com so we can investigate its settings?
