yuwanglingdi
How to add disk space indication?
Installer Enterprise > Classic theme > Enhanced UI (only install)
For the following dialogs:
- FolderDlg
I'd like to have indications of the required disk space and the available disk space.
How can I do this?
There was a reply below but I do not get it. My Advanced Installer is 13.5.
The properties you are interested in are:
-- PrimaryVolumeSpaceRequired
-- PrimaryVolumeSpaceAvailable
To have these properties set correct you will need to set the following properties like this:
- go to "Custom Actions" page
- show "InstallUISequence" -> "Begin" standard action
- create a Property set with formatted custom action under it
- set "Property Name" field to:
AiEarlyValidate
- set "Formatted Text" field to:
PRIMARYFOLDER
APPDIR
The custom actions should be using this condition:
NOT Installed
If you are not using Enhanced UI you only need to set the property "PRIMARYFOLDER", not and "AiEarlyValidate".
yuwanglingdi
Re: How to add disk space indication?
I have used the property:[PrimaryVolumeSpaceRemaining][PrimaryVolumeSpaceRequired],but when I run the installer after project builds, it shows that these two properties all are "0KB".
How can I get the right values?
The sample project is attached to this thread, so if you are interested to take a look directly at my project, you are more than welcome to download the ZIP file.
Please let me know if you have any questions.
Display volume installation info (e.g PrimaryVolumeSpaceRemaining).zip
(377 KiB) Downloaded 488 times
nateh
Dan, I've tested your example and unfortunately, it doesn't work. It only displays the text, but not the volume values next to its labels.
I have run the sample project my colleague Dan provided and everything worked as expected:
Please make sure that you have added the properties, like in the sample project:
