MLiss@Cetrus.com
Install as Administrator not working
I have a computer that has UAC set as follows:
My installer is set to "install as administrator"
However, when I run the installer in silent mode, I get :
MSI (s) (48:30) [08:11:55:261]: Product: Agent -- Error 1730. You must be an Administrator to remove this application. To remove this application, you can log on as an Administrator, or contact your technical support group for assistance.
( see the attached install log for full detail )
Why does this happen
2016.12.29.08.11.52.891_AgentInstallLog.txt
(146.66 KiB) Downloaded 247 times
Re: Install as Administrator not working
It seems the related error is triggered by the removal of the old version of your product during the upgrade installation. To further investigate your installation scenario can you please send us to support at advancedinstaller dot com the AIPs (project files) of your old and new product version?
