$uka
13.5 Pre-install UI problem
I'm using pre install ui with UI Level = Basic UI and progress.
However it looks like this:
How I can fix the cropped font? I don't see any options to reduce the font's size. :mrgreen:
$uka
Re: 13.5 Pre-install UI problem
So I've played around a bit, I set the default font size Tahoma 7 and it still crops the text! So this is a bug. How I can workaround this?
Hi and welcome to our forums.
The default font style is "Tahoma", size "8" in the "Themes" page, "Text Styles" tab when a new project is created. Can you reproduce this problem in a new project? I tested it and the text was displayed correctly. Do you have a higher DPI set on your machine?
$uka
I've created new project (black theme) with default font: DlgFont8 set to Tahoma 11 and I got the cropped text, Tahoma 8 however looks correct but it's very small :). Setting DlgFont8 to default and assigning Tahoma 8 for my original project seems does not have any effect:
And my machine is pretty ordinal I got Dell p2417h, I run it on 1920 x 1080 :
http://www.dell.com/ed/business/p/dell- ... monitor/pd
I'm afraid that this is the behavior when the text size is increased, it does not fit the control size. In order to increase the size of those controls, you can go in the "Table Editor" page, "Control" table and modify the "Height" attribute of the "BasicUIDlg -> ActionText" and "BasicUIDlg -> StatusLabel" rows. If necessary, you can also modify their "Y" attribute.
This was fixed in version 14.2 of Advanced Installer released on July 26th, 2017.
