schwarzsurfer
How to show one or more dialogs depending on checkboxes
I have 3 optional dialogs in an installer project. I want to add two checkboxes and depending on the user selection the installer should show one ore more of them. I tried to do it like this tutorial:
http://www.advancedinstaller.com/user-g ... ialog.html
and it works fine for each dialog "subtree", if I check only one checkbox. But if I check both checkboxes and want do see all dialogs, it still shows only dialogs from the first checkbox. So there are three dialogs:
dia1
dia2
dia3
this is how it should work:
checkbox1 = true -> show dia1
checkbox2 = true -> show dia2 + dia3
checkbox1 + checkbox2 = true -> show dia1 + dia2 + dia3
I tried to change the condition from ' ShowMigrationDialog = "True" ' to ' ShowMigrationDialog = "True" OR ( ShowMigrationDialog = "True" AND ShowStorageDialog = "True") ' but it still didn't work...
How can I get this to work?
Thank you!
Marian
Ich weiß, dass ich nichts weiß!
schwarzsurfer
Re: How to show one or more dialogs depending on checkboxes
I fixed it. I had to play around a little bit with the conditions for "show dialog" on the "next" and "back" buttons but now everything works fine.
Greetings
Marian
Hi Marian,
I'm glad you got this working. You can also take a look on the "How to display some dialogs depending on the selected features" tutorial that describes a similar scenario.
