MLiss@Cetrus.com
Registry search broken?
I have created a new install project.
The only thing I modified was to create a search.
When I run the search test, the search does not return the value from the value in the key.
I have attached my sample project
Here is my AI info: ( I can't upgrade yet... as we are in the middle of a final release cycle )
RegSnif.aip
(12.22 KiB) Downloaded 322 times
Last edited by MLiss@Cetrus.com on Thu Jan 12, 2017 3:12 pm, edited 2 times in total.
MLiss@Cetrus.com
Re: Registry search broken?
Here is my registry:
Here is my search:
Here is the results of the test
Hi Mike,
Please keep in mind that on a 64-bit machine, the installer is searching by default only in the 32-bit registry locations (under Wow6432Node), but if you want to search in a 64-bit location, you can check the "Search the 64-bit portion of the registry" option for your search. Can you test this and see if it works?
MLiss@Cetrus.com
yep... I put values in BOTH locations... doesn't work in either
Hi Mike,
Indeed, it seems that the search does not work in all cases when the search type "The value contains a path to a directory" is used. It seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Meanwhile, you can use the "Retrieve the raw value" type or create a custom action to verify if that is a path to a directory.
