Eric_Liu
WinPcap repackaging
Hi Support team,
WinPcap is the prerequisite software for wireshark for packet capture.
I am attempting to repackage the WinPcap since the exe installer does not support silent installation.
I try to use Advanced installer repackaging function to repackage it.
My package works great but reboot is required in order for it to work properly. The native exe installer does not require a reboot .
I found that the npf driver services will not be loaded and the "Remote Packet Capture Protocol v.0 (experimental)" not show until the machine is rebooted.
How can I load the service without reboot by MSI package ?
https://www.winpcap.org/install/bin/WinPcap_4_1_3.exe
Re: WinPcap repackaging
I tested and replicate the behavior. Please give us some time to further investigate this and we'll get back to you as soon as we have more details.
Indeed, it seems the Repackaging operation doesn't import the "rpcad" service as a service item (i.e. in "Services" page) in your repacked setup. Instead only the service configuration registries are imported (i.e. in "Registry" page). However, as a workaround you can manually create the "rpcad" service item in your repackaged setup project. Here is how you can proceed:
1. go to "Registry" page and delete the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\rpcapd
2. go to "Services" page and add a "New Service Installation " operation configured like this:
3. configure the service control operation like this:
4. rebuild and test again the installation.
In what regards the NPF driver repackaging, I wasn't able to find out anything useful. It seems we repackage correctly the driver registry configuration. The same registries are installed by the original installation package too. Can you please give us more details about the driver issue you are encountering after the installation of the repackaged setup?
Eric_Liu
Hi Daniel,
NPF driver is the key component for wireshark for packet capture.
It is OK to load the NPF driver if the machine is rebooted.
However, the native exe installer does not require a reboot . It load immediately without reboot.
Is it possible to load the NPF driver without reboot by MSI installer?
I'm not sure if this will help, but can you please go to Registry page and change the "Start" type of the "NPF" driver from "2" to "3" and see how this works now?
Here are the steps to follow:
1. go to "Registry" page and expand the following reg key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NPF
2. in right pane double click on the "Start" registry value and set the "Data" field to 3 (currently is should be 2)
3. rebuild the setup project
Let us know if this helped.
This was fixed in version 13.8 of Advanced Installer released on March 30th, 2017.
