Can you please tell us if the behaviour still persists when placing the custom action between the InstallExecute and InstallFinalize standard actions and see if the behaviour still persists?
The standard actions used by Advanced Installer can be revealed using the "Show Standard Action" button on the toolbar of the "Custom Actions" page.
I tested your sample project and it worked as expected on my machine. The "Agent.exe" application is launched in silent mode (but only in the "System Tray") as it does when it is installed with Full UI. Doesn't this work on your machine? Are you sure that the application is successfully installed in silent mode and no other error is encountered?
Yes... the application is fully installed and there are no errors. After the silent install, I am able to go to the machine where it was installed, double click "agent.exe" and it starts right up.
Our build process is this:
Dump the entire source tree
Get the entire source tree.
Build all executables
Open the aip project file
build setup
do not save any changes to any files used during build process
publish files to testing directory
My plans now are to roll back to 13.4, build again, test.
Record if agent runs after silent install
Open the aip file on my local machine using 13.4 - SAVE IT
Then install 13.5, build, test
Record if agent runs after silent install.
Open aip file on my local machine using 13.5 - SAVE IT
Post the results here
Last edited by MLiss@Cetrus.com on Thu Jan 19, 2017 8:01 pm, edited 1 time in total.
