NICOS
After successfully installation the Setup starts on every reboot
Hello!
My Setup tries to restart on every time the PC boots. But the installation was successfully, there is no need to start the setup at every reboot.
Why does the advanced installer create a task to start at every boottime? I don't create that task!
I only check the option on
- "Install Parameters"
- "Reboot behavior"
=> "Force Reboot after install"
NICOS
NICOS
Re: After successfully installation the Setup starts on every reboot
Addition: He add multiple tasks to my schedule
(1) After Package in Pre-install
(2) After Package in Post-install (second setup)
(3) After Package in Feature-based in second setup
I added 2 screens of the second task call
NICOS
Please close this Topic.
I run the setup on another PC and there he deleted all tasks and doesn't try to restart the setup again after reboot
Hi and welcome to our forums.
I'm glad the problem is solved. Just let us know anytime you need help.
