MLiss@Cetrus.com
License agreement window not showing
The license window does not show up
when I run the attached installer on the following system:
HardwareInventory.zip
(33.98 KiB) Downloaded 248 times
MLiss@Cetrus.com
Re: License agreement window not showing
The license window does show up after I Alt-Tab to another application (which causes a redraw of the installer window )
MLiss@Cetrus.com
Here is the screen resolution:
screen resolution.png (43.38 KiB) Viewed 4340 times
MLiss@Cetrus.com
NOTE: this can be reproduced on two separate systems in our office.
Hello Mike,
This happens because you didn't enable the "Enhanced User Interface" feature. Please note that, excepting the "Classic" one, all our themes (from "Themes" page) are requesting the EUI feature enabled. They are rendered correctly only when the EUI is enabled. Also, when the EUi is enabled you should build and run (at install time) an EXE setup package type.
So, please enable the EUI feature and test again your installation setup.
