dlenis
Html host control issues
I am having issues with the backspace key when filling inputs in an html host control. The backspace will not work on the input field, the back arrow does. I’ve tested the html control in Internet Explorer with no issues. Is this a limitation of the host control?
Test html.png (5.94 KiB) Viewed 2827 times
Thank you,
Diego
Re: Html host control issues
Hello Diego,
I've tested the scenario, but I cannot replicate the behavior. The Backspace key always works in my test. Can you upload a small sample (AIP + HTML file) which we can test on our side too? Also, let us know on which Windows version are you testing the scenario and which IE version is currently installed there.
dlenis
Daniel,
I've emailed the test files. The backspace does work if the fields are hard coded but not if they are created dynamically by JavaScript. I've replicated the issue on Windows 7, 8.1 and 10. In each case the backspace works when tested directly in Internet Explorer but not in Advanced Installer.
Thank you,
Diego
