Tvalone
Updater Issue
I am still having an issue with Updater.
My main application has this in the Updates Configuration file URL: https://userid:password@sft.dmv.ca.gov/Updates.txt
I created an Updates project and in the Installer Download Main URL: https://userid:password@sft.dmv.ca.gov/File Generation System 3.1.1.exe
After building I upload the Updates.txt file to the server along with the above File Generation System 3.1.1.exec
I still get the
Invalid or missing updates file.
Update file
;aiu;
[Update #1]
Name = File Generation System
ProductVersion = 3.1.1
URL = https://userid:password@sft.dmv.ca.gov/File Generation System 3.1.1.exe
Size = 23037235
MD5 = f75405fc163561fa64b2e327fd76da20
ServerFileName = File Generation System 3.1.1.exe
RegistryKey = HKUD\Software\California Department of Motor Vehicles\File Generation System\Version
Version = 3.1.2.0
[Update]
Name = File Generation System 3.1.2
ProductVersion = 3.1.2.0
Size = 23037235
Flags = Os32Only
Version = 3.1.2.0
Description = File Generation System creates file from the DMV and creates files to be sent to the DMV.
BugFix = Updated to latest Chilkat Library to respond to sweet 32 threat.
Re: Updater Issue
Can you please proceed like this:
1. on the same machine where you get the Updater error open Internet Explorer browser
2. in the address field paste your updates config file URL (https://userid:password@sft.dmv.ca.gov/Updates.txt)
3. make sure the updates config file content is reached and displayed in browser
If the updates config URL can be successfully reached in the Internet Explorer browser on the related machine, then it will be useful if you create on your web server a test user account (for testing purposing) and send us to support at advancedinstaller dot com a test URL which manifests this issue. This way we can run a full test on our side and investigate the problem.
Tvalone
Re: Updater Issue
Daniel, how are you?
Here is the error I get
When I login normally I see the Updates.txt file.
This is a Secure Transport server, with sessions etc etc.
Advanced Intaller from browser error.PNG (5.26 KiB) Viewed 4837 times
Tvalone
Re: Updater Issue
I also checked the server and see that user id associated with the updater logging in via https.
Just to be clear, i fire off the updater and check the server log and see the user id logging in.
Re: Updater Issue
If the URL cannot be accessed via the web browser then it seems there is an issue with the URL you are using. Just make sure that you have configured the IE proxy settings if there is any proxy installed on your network.
Also, the URL containing the credentials embedded could not work if on the current machine there is not installed IE 9.0 or a higher version. Please take a look on our "Issue in Advanced Installer's updater program behind a proxy" thread which debates such a problem.
